  3. Customize Datatips
  • Subscribers 159
  • Views 14146
Customize Datatips
mpred
mpred over 11 years ago
Is there a way to customize what is displayed for datatips? On symbols, the default is the REF DES and the SYMBOL. I would also like to add the PACKAGE_HEIGHT_MAX so I do not need to show element and parse through the report.
Any suggestions or help would be appreciated.
  • Randy R
    Randy R over 11 years ago
    Try the following:
    Setup->Datatip Customization, select an Object Type of Symbol Instance, Select the Advanced tab on the right, then select COMPONENT DEFINITION Package_Height_Max checkbox for Value
  • mpred
    Randy, Thanks, that is exactly it. You also showed me a new set of menus, seems like they are never ending! ;-)
