  3. Error while loading the .il file
  • Subscribers 161
  • Views 17992
Cnskill
Cnskill over 11 years ago
 H,
I am new to SKILL.
Please bear with my negligence.
I am trying to run the GUI example from this forum.(oferExample.il).
I opened the command prompt and gave cnskill -i -nongraph.
the cnskill window popped up.
load "oferExample.il"
It loaded it successfully.
Then i called the function oferExample().
It gives an error "undefined function: hiCreateStringField
Please tell what i am missing or if am doing it wrong.
Anusha
  • dmay
    dmay over 11 years ago
    You are trying to run a graphical Skill command (hiCreateStringField is a "hi - human interface" command). This command creates a string field on a form and forms are only available in graphics mode.
     Derek
    cnskill is an Allegro (or rather Concept) interface to SKILL from the SPB tools - so this should really be in the PCB SKILL forum (I'll move it there in a moment).
    cnskill -nongraph actually doesn't have any graphics at all, so can't create forms. It's different from "virtuoso -nograph", where the graphics functions are still supported, but don't show up (they're displayed on a hidden display), or "virtuoso -nographE" which still has the graphics but no CIW console.
    I tried out oferExample.il in "cnskill -i" (no -nongraph), and apart from not having dbGetDatabaseType() defined (this is in the code to tweak the appearance due to a change in Virtuoso versions), it worked. You can either edit out the dbGetDatabaseType() calls, or simply do:
    procedure(dbGetDatabaseType() "OpenAccess")
    That should make it work in cnskill.
  • Cnskill
    Thank you for your reply.
    I am actually working on a windows platform.The cnskill -i doesnt work for me.
    My ultimate goal is to add a menu in Concept HDL  which will load the .il file and display the GUI.[Note:I have already added a menu in concept HDL which does not include any GU]
    So I tried using this example in  Concept HD.It didnt work.
    So I tried it out in cnskill. Even that doesnt work.
    I am kind of struck here.
    Do you have any advice for me.
    thanks,
    Anusha
    Anusha,
    I can only give limited advice because I'm a Custom IC AE and am not that familiar with Concept or Allegro.
    However, you said that it doesn't work in cnskill. It did for me (assuming that I didn't use -nongraph, and that I also defined dbGetDatabaseType() as I explained before, as the example was implemented for Virtuoso). What doesn't work about it in cnskill?
  • Cnskill
     Andrew,
    when i give cnskill -i ,It gives me an error
    Graphical SKILL interpreter not yet available on this platform.
    Please specify -nongraph argument to cnskill.
    In one of the forum http://www.cadence.com/Community/forums/p/16180/350875.aspx I just found the forms are not supported in Concept Skill. SO that should be the problem i guess.
    Thank you for your response.
    regards,
    Anusha
