  3. Garbage collection gc()
  • Subscribers 159
  • Views 15353
eDaNoy
eDaNoy over 11 years ago
Dear All,
Is there any alternative to gc().
We don't have a license skillDev to enable gc().
Im having this lag problem everytime I load a huge amount of textFile
And I noticed my allegro used a lot memory after reading such file.
 I only want to free up my memory before to start another event/function.
Please help.
  • eDave
    eDave over 11 years ago
    Garbage collection should be automatic. You shouldn't need to use gc.
    Have you made all your variables local using a let statement?
    Dave
  • eDaNoy
    I did,
    I think Im facing a problem with my table that serves as GLOBAL variable I have just noticed recently.
    This table holds all my variables...
    Table grows bigger same as memory being use to allocate cells.
  • eDave
    Huh? Why are you using a global? Avoid that if possible.
  • eDaNoy
    Im doing a previous skill Update.
    Lesson learned.. hahah table as global variable is a NO NO.
    Thanks Dave
  • fxffxf
    fxffxf over 11 years ago
    If you use a global or assign long lists to a global, assign  nil to the variable when it is no longer required. This allows Skill to free the asssociated memory. It is also a good idea to get a skill developer's license so you can run Skill lint on your code. This can point out other issues.
