  3. Centering Clines Within BGA
  • Replies 18
  • Views 26522
eddieb1
eddieb1 over 12 years ago
 Hello experts,
Is there a function that I can use to center only the clines inside the BGA area?
If so how do go I about it?
For instance, what skill code can I use to shove/move single clines or dual clines in between (or in the middle of) the BGA vias?
  - where if there are two clines in between vias, the air gap is 1x or 2x of the trace width.
Below is a simple illustration:
Single cline centered in between BGA vias:
o I o I o I o
Dual CLine centered in between BGA vias::
o IxI o IxI o
Where:
o = via
I = Cline
x = air gap between two clines.
 Note:
In some areas of the BGA, the vias are in-line while in some areas (at the periphery) the via pitch is mixed, that is a combination of 10mm and 8mm  - stagered pitch.
Eddie
  • eddieb1
     Thanks Dave for the feedback.
     Looking into this closer, I have to agree with you. It won't work since there are just too many variable to account for.
    Btw, is the Snake/Scribble a feature avaliable in the Editor or is this Router feature?
    Eddie.
  • Randy R
    Randy R over 12 years ago
    Snake/Scribble are part of the PCB Editor:
    Route->Unsupported Prototypes->Enable Add Connect Scribble
    Route->Unsupported Prototypes->Snake Router
    For help on using them:  Route->Unsupported Prototypes->Help on Unsupported Utilities
  • eddieb1
     Got it. Thanks Randy,
    I have not used this function before - time to learn something new.
    Eddie.
