  3. Cancelling axlSingleSelectPoint() ??
  • Replies 7
  • Views 17943
jwhend
jwhend over 12 years ago
 Hi all,
I want to cancel a axlSingleSelectPoint() command if the user decided not to finish. I there a way to cancel axlSingleSelectPoint()?
Jerry
  • jwhend
     Hi Dave,
    The " (form_status->curField=="cancel" || !form_status ->continue" causes the form to close as soon as you select any button. I'm not sure why.
    Here is what I have, does this make since?? Thanks for you help.
     procedure(_callback(form_status)
    let((newbox numFields)
        cond(
            (form_status->curField=="cancel" ||  !form_status->continue
            axlCancelEnterFun()
            axlDBControl('drcEnable t)
            axlUIWUpdate(nil)
            axlFormClose(form_status)
            axlCancelEnterFun()
            axlUIWUpdate(nil)
            (form_status->curField=="Reset"
            numFields=form_status->fields
            axlClearSelSet()
                foreach(Field numFields
                axlFormColorize(form_status Field 'background nil)
                axlFormSetField(form_status Field nil)
            (integerp(atoi(form_status->curField))
            newbox=atoi(form_status->curField)
            PCD_ceCreatePathTables(newbox)
            axlFormColorize(form_status form_status->curField 'background 'green)
            axlClearSelSet()
    procedure(PCD_ceCreatePathTables(etchgroup)
    let((lyr_cnt LayerTable coupon_rotation coupon_symbol coupon_x coupon_y Path1_tbl Path2_tbl Path3_tbl Path4_tbl)
        LayerTable=PCD_ceGetEtchInfo()
            axlSetFindFilter(
            ?enabled list("noall" "symbols")
            ?onButtons list("noall" "symbols")
            when(axlOKToProceed()
             form_status->continue=t
            form_status->continue=axlSingleSelectPoint()
    ;axlSingleSelectPoint()
            coupon_symbol=car(axlGetSelSet())
            coupon_rotation=float(coupon_symbol->rotation)
            coupon_x=car( coupon_symbol->xy)
            coupon_y=cadr( coupon_symbol->xy)
            lyr_cnt=1
  • jwhend
     I think I have a different work around. I placed a "when(coupon_symbol " do the rest. This way until a selection is actually made, nothing happens.
    Thanks for the suggestions.
    Jerry
