  3. error in "if" statement
  • Subscribers 159
  • Views 1604
Guye
Guye over 11 years ago
the error is: E- *Error* if: too few arguments (at least 2 expected, 1 given) - (member(via_net net_list))
code:
net_list=list("VDD" "VSS")
sel_via_dbid=axlGetSelSet();listing the selected via's
foreach(via sel_via_dbid
net_dbid=via->net
via_net=net_dbid->name
if(member(via_net net_list)) then
println("net name is VDD or VSS")
else
println("net name is:%s" via_net)
what am i missing here? Thanks, Guy
  • eDave
    eDave over 11 years ago
    You have a misplaced ).
    Try:
    net_dbid=via->net
    if(member(via_net net_list) then
    else
    You should use an editor with bracket matching. I use UltraEdit.
  • Guye
    thank you very much :)
  • mikebystedt
    mikebystedt over 11 years ago
    NotePad++ is available for free and supports a good number of language highlighting.  Including SKILL.
  • Guye
    Thanks for the editor recommendation. I'm using gVim and it has a Lisp & skill syntax highlight. but i guess its not perfect ...
