  3. How to get path of trace connected to via or thru pin
  • Replies 7
  • Subscribers 159
  • Views 16908
seyerfred
seyerfred over 11 years ago
Hi all,
 How can i get the path origin(xy) of traces connected to via or thru pin component?
Thank you
  • eDave
    eDave over 11 years ago
    Use axlDBGetConnect to get the connections to a pin or via.
    Use axlPathGetPathSegs to get the segments of each path returned from axlDBGetConnect
    Use axlPathSegGetEndPoint on each segment to get the points along the path.
  • seyerfred
    Hi Dave,
    Thanks for reply, ok i will try that..
  • seyerfred
    Hi Dave,
    btw is it possible to encrypt my skill file into context without skillDev enabled?
    Thank you.
  • eDave
    Take a look at the "Building Contexts in Allegro" in the Skill Language Reference Guide.
  • seyerfred
    i already explore building context in allegro but when savecontext key in it says skillDev not enabled.
    i dont have a license for skillDev, is there any possible way to encrypt in context without license?
    thank you.
