  3. Exiting my skill code when a new command is started
  • Subscribers 158
  • Views 13498
Randy R
Randy R over 11 years ago
How do I detect and gracefully exit my skill code when a new Allegro command like "slide" is started?  If another command is started while I'm waiting for a selection, the new command is put on hold until Cancel or Done is selected in my popup; then the new command starts.  I would rather have my code do a "Done" when the new command is selected so the new command starts right away (similar to how you can go from one Allegro command to another with selecting Done; i.e. Slide to Add Connect.
;setup popup with Cancel/Done items
while( axlSelect()
;    user selects database items and they are modified based on input form settings
);end while
