  3. How to deal with backslash"\" in Skill Code
  • Subscribers 160
  • Views 1628
leonlee
leonlee over 11 years ago
 Hi All,
I met an problem about the backslash character, as it is "\\" in Skill language, and there is a line of code like below:
axlShell( "system @rundll32.exe %SystemRoot%/System32/shimgvw.dll, ImageView_Fullscreen D:\test\test.jpg" )
This is not support by Skill.
axlShell( "system @rundll32.exe %SystemRoot%/System32/shimgvw.dll, ImageView_Fullscreen D:\\test\\test.jpg")
This doesn't work either.
axlShell( "system @rundll32.exe %SystemRoot%/System32/shimgvw.dll, ImageView_Fullscreen D:/test/test.jpg")
cmd.exe supports: @rundll32.exe %SystemRoot%/System32/shimgvw.dll, ImageView_Fullscreen D:\test\test.jpg
But Allegro CIW doesn't support system @rundll32.exe %SystemRoot%/System32/shimgvw.dll, ImageView_Fullscreen D:\test\test.jpg
So, how convert "\\" into "\"?
Thanks.
  • Ejlersen
    Ejlersen over 11 years ago
    Hi
    In the past I've created batch (.bat/.cmd) files and executed them using system instead. If you create the .bat file in a known location like currentWorkingDir then you know where to execute it from.
    To circumvent unc paths you can use info on http://en.wikipedia.org/wiki/Pushd_and_popd to create temp drives.
    Depending on what you're trying to do with the above commands there may be other ways to do the same without rundll32.exe
    Best regards
    Ole
  • leonlee
    Thanks Ole, for your suggestion. For a single task, it's a good solution to create temperary .bat file.
    In fact, my purpose is to run the task with variant. "D:\test\test.jpg" is just a sample, I'll write the variant in my codes.
