  3. Problem with scripts that require file browsers
  • Replies 11
  • Views 21567
mikebystedt
mikebystedt over 12 years ago
Does anyone know of a workaround that would allow a script or axlShell() commands to select and populate a
file browser if it pops up?  It seems that the file browser form isn't recgonized.  So therefore no data can be entered.
Specifically, after doing a File->Import and running, a summary report pops up with the details.  When I select "Save",
a browser window pops up, but during Replay, the window is never selected, the filename never entered, and I can't
save the file.
I'm sure that someone else has encountered this at some point.  Any suggestions?
Is there some sort of default FORM name that I could refer to that isn't being output to the script file during a Record session?
Thanks, -Mike
  • Helen
    Helen over 12 years ago
     Add  "viewlog -last" and you code will save "MIKEtest.txt". By default this report saved to ./Logs/netrev.lst
    netin
    setwindow form.niparams
    FORM niparams import
    setwindow pcb
    viewlog -last     ### <========
    setwindow text
    save
    fillin "MIKEtest.txt"
    setwindow text
    close
    FORM niparams cancel
    setwindow pcb
    generaledit
