  3. How to make a program run as a non-blocking command?
  • Replies 7
  • Subscribers 159
  • Views 16380
thewill2live
thewill2live over 11 years ago
Hey Guys,
 So I wrote a Skill program that spits back the XY coordinates in a text box for a symbol that is clicked on so that it can be easily copied and pasted (rather than highlighting it in the show_info box). What I need now is for this program I wrote to be able to be called in the middle of say a MOVE command without killing off the currently running command. How would I go about doing that?
 *Bonus point: Is there a way to paste the info from a skill variable (say "foo") to the Allegro command line buffer so that it appears as in the command line as "Command> foo"
Thanks for any help you can give me.
-Will
  • Tyler
    Tyler over 11 years ago
    When you register your command with axlCmdRegister, to make it run while other commands are up and running, set the command's type to general. You can look up the function documentation for all the options that can be set for the command, but a simple example would be:
       axlCmdRegister("my_command" 'mySkillFunction ?cmdType "general")
    This will keep it from exiting the other command when starting yours, which sounds like what you want.
    As for your bonus point question, you can run commands on the command line shell from skill by calling axlShell(<my string>). If the string you want to send is stored in a variable, just call axlShell(<varName>). I don't think you can just "paste" stuff in there, though. It's going to try and execute what you send to the command shell.
    Cheers,
    - Tyler
  • thewill2live
    Ah very nice. Thanks for the tip about the command type. As for the the axlShell I've tried that, you're right it just executes as a command. Useful but not for this project that I'm working on. Thanks anyways.
    -Will
  • Tyler
    That's what I figured in terms of the shell pasting. Maybe one thing you could do is pipe the value to the windows (or linux, whatever OS you're using) clipboard, so you could just do Control-V to paste it where you want it? For instance, you could do the following from skill on a windows machine:
       sprintf(myString "echo %s | clip" myVariable)
       shell(myString)
    Which should put the contents of your variable into the clipboard buffer, which you could then paste to the command line in the Cadence tool? Not perfect, but depending on what you're doing, might be a decent workaround?
    Cheers,
    - Tyler
  • thewill2live
    This is perfect! I had thought about passing it to the windows clipboard. I just didn't know how to do that from inside Skill. Thanks!
  • Tyler
    My pleasure. Thanks for giving me a brain teaser. Happy coding!
