  3. keep a form open when run "undo" command
  • Subscribers 159
  • Views 1592
Tiger LIU
Tiger LIU over 11 years ago
Is there a way to keep a form open when run "undo" command?
Seems that all forms will be closed after "undo".
 Thanks.
  • eDave
    eDave over 11 years ago
    The behaviour is incorrect but you can avoid it by creating your form in non-blocking mode.
  • Tiger LIU
     Hi eDave,
    Thanks for your answer.
    But no matter non-block is t or nil, the form will be closed. My code:
    cbc_mcp_form = axlFormCreate( (gensym) "cbc_mcp_file.form" '(ne inner) 'cbc_mcp_form_callback t)
    cbc_mcp_form = axlFormCreate( (gensym) "cbc_mcp_file.form" '(ne inner) 'cbc_mcp_form_callback nil)
    Is there something wrong with my code?
    Thanks.
  • D912349
    D912349 over 11 years ago
     H,
     Try using axlUIWPerm(form t/nil). put the line after loading your form
          t/nil determines if you want the form to be permanent or reset it back.
  • Tiger LIU
     Aha, that works!
    Great, thanks.
