  3. Problem Calling batch programs in SKILL
  • Subscribers 160
  • Views 14392
thewill2live
thewill2live over 11 years ago
Hey guys,
I'm thinking I may have a setting wrong or am missing something here but I'm trying to call the "artwork" batch progrm  C:\Cadence\SPB_16.6\tools\pcb\bin\artwork.exe in my code and I'm using the following lines
artworkLay = axlGetParam("artwork")->groupMembers
sprintf(artCmd "artwork -f %s" nth( 0 artworkLay))
axlRunBatchDBProgram("artwork" artCmd)
However running this results in Allegro bringing up a window with a progress bar and running indefinitely (it never ends, just keeps counting the time). I ran into this once before when I tried to run the dumb_libraries program that eDave suggested to me in another post (www.cadence.com/.../1336333.aspx. Same thing happens, the command appears to run but never finishes and nothing ever outputs. Is there a setting somewhere to point Allegro to those .exe files? My guess was that the program is hanging while it searches the computer for the .exe it needs. Any thoughts? I've tested the axlRunBatchDBProgram command with calling something simple like notepad and that works fine it's just the allegro ones that I can't seem to call.
-Will
  • Ejlersen
    Ejlersen over 11 years ago
    Hi Will
    Checking if artwork is in the path is  easy, just do Windows button + R to run a program, type artwork and press enter.
    It should open a cmd prompt and ask for a board name.
    Reading the help for artwork.exe in C:\Cadence\SPB_16.6\share\pcb\batchhelp\artwork.txt says you need to specify the board filename also, not sure if this is the missing link here but seems to work for me)
    So try sprintf(artCmd "artwork -f %s %s.brd" nth( 0 artworkLay) axlCurrentDesign())
    Best regards
    Ole
  • thewill2live
    I have run the batch programs from the command line before and they worked just fine. You were right, the missing element here was the brd file name in the command. I added that in and it ran just fine. (Well sort of, it did tell me there were errors in the artwork and opened a file browser to look at logs but that has nothing to do with my code haha). Thank you for the help!
  • fxffxf
    fxffxf over 11 years ago
     You should use the
          sprintf(artCmd "artwork -f %s %%s")
    This will use the current in-memory design.
