  3. skill code to copy lines to subclass
  • Replies 7
  • Subscribers 160
  • Views 15386
Ejlersen
Ejlersen over 11 years ago
Hi
I was wondering if someone had some code to share to copy lines to another subclass?
If not, I'll just have to do it on my own :-)
Thanks in advance.
Best regards
OIe
  • eDave
    eDave over 11 years ago
    Hi Ole,
    See attached. It can be used to move or copy, lines shapes or text.
    Cheers,
    Dave
    DE_moveObjsToLayer.zip
  • Ejlersen
    Hi Dave
    Thanks for the code, do you happen to have the layer selection and object selection code (area, temp group, lasso etc.) for it as well?
    Best regards
    Ole
  • eDave
    Sorry Ole, not currently for this function.
    Also, if you are not moving clines but lines on non-etch classes, you may just prefer to use axlCopyObject and axlChangeLayer.
    Dave
  • Ejlersen
    Hi Dave
    No problem, just had a customer that asked for this functionality - but will consider doing it at some point where I have time left to do this. I want to try doing it with axlMiniStatusLoad which I've never tried before and it seems a bit cumbersome to get to Work.
    Best regards
    Ole
  • luanvn81
    luanvn81 over 11 years ago
     Hi guys, Normal 0 false false false MicrosoftInternetExplorer4
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
    I'm sorry but How can I make it go to work?  I have tried to  give it "axlCmdRegister( "DE_moveObjsToLayer" `DE_moveObjsToLayer)" and run it but got error ==>  E- *Error* DE_moveObjsToLayer: too few arguments (at least 2 expected, 0 given) - nil   (-_-)(-_-)(-_-).
    Tks.
    Luan
