  3. Set NC Parameter and Art Parameters from SKILL?
  • Replies 15
  • Subscribers 166
  • Views 26704
thewill2live
thewill2live over 12 years ago
Hey guys,
 I'm currently working on a program to output artwork and NC Drill files. I have them outputting by calling the batch commands "artwork" and "nctape" respectively. However, this doesn't output the standard Art_param.txt and NC_param.txt files that are normally output when you manually output artwork and NC Drill data from Allegro. My work around for now is that I noticed these .txt files are generated when accessing the parameters tab on each of those windows (even without changing anything, you just have to access the pages) so I recorded a script of me opening those windows, changing to the parameters tabs, and closing the window. By running these scr files using the "replay" command I am able to generate the param.txt files I want. I wanted to ask if anyone knows of a true SKILL way of outputting these files and/or setting these parameters? Workaround is fine but I'd rather not rely on the .scr file being called.
Bonus question: Is there a way to modify the default directory of the files I am currently outputting? For instance when I run "artwork" right now it outputs all the .art files into the same directory that my .brd file currently resides in. Is there a way of saying put everything in this FOO folder I made in this directory?
  • oldmouldy
    oldmouldy over 12 years ago +1
    You don't need to do this with SKILL, the "artpath" is scanned for "art_param.txt", create the file and the set the preference to pick it up, User Preferences / Paths / Config / artpath, the "ncdpath"…
  • DE202408202727
    DE202408202727 over 12 years ago
    I'm not familiar with Python but the system command would look something like this:
    system("python.exe foo.py")
    Yes, an exe might be better.
  • thewill2live
    That worked like a charm. Thanks Dave! Now if you have any idea how I can make a skill program to mimic the "last command" ability of windows and unix command lines then I might just have to buy you lunch the next time you're in my part of town haha.
  • DE202408202727
    No problem!
    Yes, it would be nice to have command-repeat functionality along with multi-line entry in the Skill console.
  • Ejlersen
    Ejlersen over 12 years ago
    Hi
    Yes, I backup that,command repeat in normal command window would also be excellent
    Best regards
    Ole
  • AK20250513568
    AK20250513568 over 1 year ago in reply to oldmouldy
    This is probably the easiest method. Thanks.
