  3. CONCEPT_HDL_SKILL
  • Subscribers 160
  • Views 16312
CONCEPT_HDL_SKILL
KARPCB
KARPCB over 11 years ago
 Hi All,
Is it possible to write a skill code for concept HDL? - its possible means please let me know  the any quidelines , any sample codes and how can i load in to sch.
Karthik.
  • eDave
    eDave over 11 years ago
    Yes. It is quite possible.
    Start with the Allegro Design Entry HDL Skill Reference manual: <install folder>\doc\conceptsk\conceptsk.pdf
  • KARPCB
    Thanks Dave.
  • KARPCB
    Hi Dave,
    Now i am doing script and skill in concept hdl.
    script is working fine.but, im trying to load skill file in concept hdl via console window. it's shows  WARNING(SPCOCN-1169): Unrecognized command: <skill>.
    please let me know how to load the skill file in concept hdl.
    here i have attached sample skill file(taken from hdl skill.pdf)
    Karthik.
    handle.il
  • KARPCB
     Please refer the attached image.
  • eDave
    Unlike Allegro Skill, you need to run a separate console to run Skill in Concept. It communicates with Concept using Inter-Process Communications. This should all be in the manual. I have a small script that contains the following:
    mpsdeclare pcskill
    mpstool=cdscnCmndsServer
    mpsruncommand="cnskill -i -nongraph"
    pcskill
    I run this to start Skill. The first command that you will then need is: handle = cnmpsImport()
