  3. change the line font of a rectangle?
  • Subscribers 159
  • Views 14780
jwhend
jwhend over 11 years ago
 Hi all,
I am trying to create a rectangle, using axlDBCreateRetangle, but there does not seem to be an option for line font. I want to use PHANTOM. Is there a way to change the line font in skill? I know I can change a "line" with axlChangeLineFont, but a rectangle is considered a shape in allegro.
Anyone have a work around for this?
Jerry
  • Ejlersen
    Ejlersen over 11 years ago
    Hi
    How about using axlDBCreateLine to draw a rectangle and get the linefont?
    That should not take up too much code work :-)
    Best regards
    Ole
  • jwhend
     Hi Ole,
    I already thought about that, but this is used in a program that automatically creates a fab drawing and I wanted to stick with a rectangle.
    I would need to ask a commitee if there would be an issue with moving to a line, pretty sure there is not. Anyway, I will probable go with a line.
    Cadence has addressed the issue:
    " Regarding Case 45639321, "Setting line font before using axlDBCreateRectangle?." I hope the axlDBCreatePath() function should have helped you in setting the line font. But this is a longer way to create rectangle and so I have filed Cadence Change Request (CCR) number 1317539 on your behalf. The CCR is Enhancement for axlDBCreateRectangle() and asked R&D to add two formal arguments for Line Font and Line Width."
    Jerry
  • Ejlersen
    Hi Jerry
    Exciting to see what happens with the CCR, currently the line of a closed shape, even if unfilled, is zero as you may already know.
    No matter how you try to trick it I cannot see a way to get another line font without involving real lines as it is today.
    Best regards
    Ole
  • jwhend
    Looks like it is going to happen in SPB16.60.039 release. The fix for your CCR(s) is/are going to be included in the release(s) listed below. Click here to update your COS notification preferences so you will be notified when the release is available on downloads.cadence.com.
    CCR Number Case Number Release Name Platform
    1317539 45639321 SPB16.60.039 ALL
