  3. how to work around limits in axlDBGetExtents
  • Subscribers 159
  • Views 14172
Ejlersen
Ejlersen over 11 years ago
Hi
I'm using the axlDBGetExtents function to get the extents but are running into issues depending on the number of dbids in my list.
So in some cases I run into issues simply due to the length of the list of dbids and axlDBGetExtents return "nil"
Is there any kind of workaround for this?
I know that 1487 dbids are ok whereas 2520 are not
Thanks in advance
Best regards
Ole
  • fxffxf
    fxffxf over 11 years ago
    Look into if the list contains an  unsupported dbids. GetExtents only supports segements, clines, lines, rect, filled rect, figure, text, shape, voids, pins, vias and symbol instances. If you have dbids like nets, symbol defs, or groups it will fail.
  • Ejlersen
    Hi
    I'm using the find filter to select with the command
    axlSetFindFilter(?enabled list( "noall" "vias" "shapes" "pins" "clines" "lines" "figures")
    ?onButtons list( "noall" "vias" "shapes" "pins" "clines" "lines" "figures")
    Printing the list for objType exhibits the following types
    pin, path, via, shape, polygon
    That does not look like symdefs
    Bonus question, if I do the printing in the skill development window there seem to be a limit of 296 lines, how can I circumvent that limit?
    Best regards
    Ole
  • fxffxf
     I would call GetExtents for each element and see what it rejects (returns nil)
    The skill code: for(i 1 1000 printf("i=%d\n" i))
    has no trouble echoing 1000 lines to the Skill window
  • Ejlersen
    Hi
    Your printing code works fine for 1000 lines, but when the skill window reports my dbid list it ends with 3 points
    http://screencast.com/t/e2oA8a4B0uZ
    Also, if I create a loop on all dbids and write the type to skill dev window or file it will stop after 296 items (suppose thats the number of dbids it shows when returning after axlGetSelSet())
    I'll try iterate over getextents
    Best regards
    Ole
  • Ejlersen
    Hi
    Just a quick update.
    Iterating over all dbids and removing dbids that return nil solves the issue
    I found out that the problem was related to a slot hole that had no pad definition but still got selected as a pin on the subclass that was visible. But axlDBGetExtents return nil
    Best regards
    Ole
