  3. How to extract over thousands of symbol's subclass with...
  • Replies 10
  • Views 9688
How to extract over thousands of symbol's subclass with skill?
abdulhalim
abdulhalim over 12 years ago
I am trying to automate a process of extracting symbol's DFA_BOUND_TOP and PLACE_BOUND_TOP using skill.
The symbol's are all located form our library's directory which can be placed on the board through Place -> Manually -> Select Advanced Settings tab to check the library box -> Select Placement List tab and select package symbols in the dropdown menu.
Steps what I would like for SKILL to be used:
  1. Open up Allegro PCB Editor (select desired product)
  2. Change the board grid size to millimeter
  3. Select Color192 (Ctrl + F5) to turn global visibility off besides DFA_BOUND_TOP and PLACE_BOUND_TOP
  4. Place symbol from library
  5. Get symbol's DFA_BOUND_TOP and PLACE_BOUND_TOP subclasses using "Show Element (F4)" with "shapes" under find option.
  6. Export the "Show Element" Box in .txt with symbol's name (ie: resistor1.txt).
  7. Repeat steps 4-6 until all the symbols from library .txt have been exported
  8. Close Allegro PCB Editor
Right now I have the process that is being done using the record macro. Unfortunately, it cannot use conditional or decision making, for example to name the file according to the symbol and implementing a for/while loop.
Any help or guidance is much appreciated.
If there's any questions please feel free to ask.
I am on 16.6.
  • abdulhalim
    Thank you,
    If anyone else interested I can provide a template which Cadence Support assisted with me below:
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/lib_5F00_info.il
  • mpred
    mpred over 11 years ago
    Dave, I am trying modify what you provided to simply print the property DFA_DEV_CLASS of the open *.dra file. I am not too familiar with Skill. Any help would be appreciated.
  • jgmellom
    jgmellom over 11 years ago
    Where you able to extract the DFA_DEV_CLASS property?  I'm looking to do the same thing.
  • DE202408202727
    DE202408202727 over 11 years ago
    axlDBGetDesign() ->prop ->DFA_DEV_CLASS
  • jgmellom
    Thanks for the prompt reply....that worked perfectly.
