  3. Excel File Reading Question
  • Subscribers 160
  • Views 16427
thewill2live
thewill2live over 10 years ago
Hey Guys,
I'm trying to read in an excel file to get some data and display it on a GUI. I have been trying the following:
file = axlDMFileBrowse("MISC" nil)
print(file) ;DEBUG
if( axlSpreadsheetRead(file)
then
println("Successfully Read spreadsheet!") ;DEBUG
println(axlSpreadsheetGetCell(1,1)) ;DEBUG
with test.xlsx file and get this error:
E- (SPMHWB-110): Error importing XML file An exception occurred! Type:UTFDataFormatException, Message:invalid byte 1 (‚) of a 1-byte sequence..
I'm guessing this means that Allegro doesn't like .xlsx files, so I tried the same with a test2.xls file and got pretty much the same error:
E- (SPMHWB-110): Error importing XML file An exception occurred! Type:UTFDataFormatException, Message:invalid byte 2 (Ï) of a 2-byte sequence..
E- (SPMHWB-110): Error importing XML file .
Both times it dies on the axlSpreadsheetRead command. My temporary work around is to use .csv files and change to the axlSpreadsheetReadDelimited command which is working fine but I'd like to know what I'm doing wrong on the excel side as I would like to be able to support all 3 file types (xlsx, xls, and csv). Anyone have an idea where I went wrong?
Bonus question: Does SKILL have an exception handling method? I attempted to follow a tutorial for LISP exception handling using the "Condition" system but Allegro didn't like that when I attempted to run it. I'm hoping there something along the lines of the python try/except/else statement that will allow me to put some exception handling abilities into my program. Does this exist?
  • fxffxf
    fxffxf over 10 years ago
    Try  after axlSpreadsheetRead
       axlSpreadsheetGetWorksheets to get worksheets in file
    then set active worksheet
        axlSpreadsheetSetWorksheet(< a worksheet from above>)
    then axlSpreadsheetGetCell
  • thewill2live
    I updated the code to the following:
    print(file) ;DEBUG
    print("Got past READ line");DEBUG
    wrksht = axlSpreadsheetGetWorksheets()
    print("Got past Get Worksheet line");DEBUG
    axlSpreadsheetSetWorksheets(nth(0 wrksht))
    print("Got past Set Worksheet line");DEBUG
    cell = axlSpreadsheetGetCell(1,1)
    print("Got past Get Cell line");DEBUG
    println(cell)
    But never get past the axlSpreadsheetRead(file) line anyways. Same error as above occurs.
  • B Bruekers
    B Bruekers over 10 years ago
    From the documentation:
    The axlSpreadsheet family of functions allow you to read and write Microsoft's open XML- based spreadsheet format from within skill.
    This means you can only read / write XML based files. So xls and xlsx are not supported.
    You could write a VBS script and run it with 'csrcipt' to first save the XLS file to a XML format and then import it.
    Same for exporting/merging data into a XLS file.
    All this you can do from SKILL.
    For the exception handling use errset().
  • thewill2live
    It is my understanding that .xlsx was the microsoft open XML-based spreadsheet (as opposed to .xls which is the older non-xml version). So if this is not true, can you give me an example of what file type IS supported by the axlSpreadsheet commands (aside from the .csv file)?
    For the exception handling, thanks I'll take a look at that function.
  • Ejlersen
    Ejlersen over 10 years ago
    Hi
    I would recommend that you read the information in %cdsroot%\share\pcb\examples\skill\doc\funcs\axlSpreadsheetDoc.txt
    It contains a sample that writes a spreadsheet (in .xml format) - from there you can see the format and how to read it.
    Best regards
    Ole
