  3. axlExtractToFile, is there a limit to the list of output...
  • Subscribers 158
  • Views 13726
axlExtractToFile, is there a limit to the list of output files?
jwhend
jwhend over 10 years ago
Hi all,
I am trying to use a multi-view extract view file with axlExtractToFile. There are more than 16 views in the view file and when I try and use axlExtractToFile the extracts stops at 16. Is there a limit to how many views you can have in one file?
netFiles is a list of 20 output file names to be used.
when(netFiles
    axlExtractToFile("./48V_view.txt" netFiles)
    ;parse out the info I need from each output file
        foreach(v48nets netFiles
        v48nets=strcat(v48nets ".txt")
        extractOut2=infile(v48nets)
            while(gets(strOfNets extractOut2)
            checkForS=symbolToString(getchar(strOfNets 1))
                when(checkForS=="S"
                fprintf(netviews strOfNets)
                );when
  • fxffxf
    fxffxf over 10 years ago
    24
    at the terminal you can do
       extracta -help
  • jwhend
    I wondering if it maybe different tor axlExtractToFile()? My code stops at 16 when there are 20 output file names.
  • fxffxf
    for axl Extract the limit is 15, If you need more the 15 views, divide your viewFile into multiple files and call extract multiple times.
  • jwhend
    Thanks, that's what I was looking for. Did you find this in the docs?
