  3. Replacing padstack with script
  • Subscribers 159
  • Views 14872
kmacshane
kmacshane over 10 years ago
I would like to mimic the function of 'Tools->Padstack->Replace' with a SKILL script.  As I understand it, the axlReplacePadstack function only works with a specific pin or list.  What do I use if I want to replace a padstack for all pins with that padstack, without already having a list of the pins?
I am referring to this documentation on axlReplacePadstack. Please let me know if there is different documenation I should be using. Thanks!
  • eDave
    eDave over 10 years ago
    see attached.https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/replacePads.il
    Cheers,
    Dave
  • kmacshane
    Dave,
    Thanks for the quick reply.  However, it looks like the code is meant for selecting multiple vias and then replacing the padstack...I'd like to be able to select the vias based on the padstack on load.  The idea is that a default layout is then automatically edited to replace a padstack with another without input from the user.
    I'm new to SKILL so if I misunderstood the code, I apologize.
  • eDave
    Hi Kelly,
    I only provided that code as an example. Attached is more code to do what I think you want.
    The function is AFn_replaceAllPinsOrViasByName. Pass it the name of the via to be replaced and its replacement.
    eg AFn_replaceAllPinsOrViasByName("VIA_OLD", "VIA_NEW")
    This wil replace all vias with the name "VIA_OLD" with "VIA_NEW".https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/4428.replacePads.il
  • eDave
    replacePads.zip
  • kmacshane
    Dave,
    That was exactly what I meant, thank you.
    Kelly
