  3. Loading constraint file in SKILL
  • Subscribers 159
  • Views 13648
kmacshane
kmacshane over 10 years ago
Is there a way to import a constraint file (.dcf) with a SKILL function?
  • Kirti Sikri
    Kirti Sikri over 10 years ago
    If you want to load the same dcf file You can Record the script using File->Script to open Constraint Manager import the dcf file. Say you record the script as loaddcf.scr. You can invoke this script using following command on the Allegro Command window skill axlShell("replay loaddcf.scr") If you different dcf file then you would have to tweak the script.
