  3. SKILL in Concept HDL
  • Subscribers 159
  • Views 13920
hostSouthern
hostSouthern over 10 years ago
Hi All,
I have 2 problems while using SKILL in Concept HDL.
1. I initiate SKILL follow the aid from this forum to run the script bellowed.
mpsdeclare pcskill
mpstool=cdscnCmndsServer
mpsruncommand="cnskill -i -nongraph"
pcskill
This will successfully open a cnskill console but Concept will be busy for a while and return a message as bellowed:
MPS service not available.
Tool=cdscnCmndsServer Service=cdscnCmndsServer Version=.*. SessionName=10310019_ProjectMgr30808  SessionHost=AN990109654
Although this error message popped up, I still can get information from drawing for my SKILL code.
Is there anything I missed for setup SKILL environment?
2. After I run my custom SKILL code for whole design, I try to do "save hierarchy"  but can't successfully do it.
A new cnskill console pops up and doing nothing.
It seems the command " hier_write  " had been overwrite or missing.
I type instruction followed  "concepthdl.scr" as
mpsdeclare uprev_write s2l hier_write _!cdsattribute
mpsruncommand="cnskill -nongraph cdscnCmnds.ini"
Now I can do save hierarchy but if I try to open skill console with command declared in the previous issue"pcskill", it failed.
get this message in command console window  ==> "Command callback declaration list for pcskill not found."
I can't open cnskill console again even rerun script in issue1 until I close Concept and reload design.
Did I missed any required operation for MPS?
CF
