  3. How to open excel file in skill
  • Replies 13
  • Subscribers 167
  • Views 27948
luanvn81
luanvn81 over 11 years ago
Hi all!
 I  have created a .csv file in my skill code, but I don't know how to open it  by skill, I have search out the function axlPdfView only. I don't know if is there  any function to open excel fife like that, Please show me to do that.
Thank you.
Luan.
  • Kirti Sikri
    Kirti Sikri over 11 years ago +1
    Hello, If its a csv file delimited by same ,(comma) you want to open then you can open using regular file function infile, use gets to read lines from file as string and axlStringCSVParse to parse…
  • Kirti Sikri
    Kirti Sikri over 5 years ago +1
    You can read an Excel file using SKILL by using the axlSpreadsheetRead API, but the file is expected to be in Microsoft XML open spreadsheet format. Article How to read an Excel file using Allegro SKILL…
  • edwards142
    edwards142 over 5 years ago
    Honestly speaking I don’t know how to open Excel file in skill. But I know some quick tricks to open your Excel file even if you don’t have the proper Excel application installed in your device.
    To grab detailed information regarding this, just tap to this given link: 10 Alternative Options To Open Excel Files Without Excel
  • Karsten B
    Karsten B over 5 years ago in reply to edwards142
    I am using axlHTTP.
    This works with driveletters. E.g. : axlHttp("D:/Test.xls")
    and with direct access to a server, e.g. axlHTTP("file://SERVER0815/MyFolder/Test.xls")
  • Kirti Sikri
    Article How to read an Excel file using Allegro SKILL explains the error while reading an Excel file by using the API. It also explains how to save the Excel file in Microsoft XML open spreadsheet format and shows the usage of the axlSpreadsheetRead API.
    For text-delimited files, the API to be used is axlSpreadsheetReadDelimited.
    axlSpreadsheetReadDelimited(t_fileName, t_delimiter)
    ==> t / nil
    Description
    Read a text file on disk into memory for data access and manipulation as a spreadsheet. File is expected to be a delimited text file, with cell delimiters as specified in the t_delimiter argument. For XML spreadsheets, use axlSpreadsheetRead.
    axlSpreadsheetRead("example.txt", ",")
        ==> t
    axlSpreadsheetGetCell(1 1)
    axlSpreadsheetClose()
     ==> t
