  3. How to open excel file in skill
  • Replies 13
  • Subscribers 162
  • Views 24160
luanvn81
luanvn81 over 10 years ago
Hi all!
 I  have created a .csv file in my skill code, but I don't know how to open it  by skill, I have search out the function axlPdfView only. I don't know if is there  any function to open excel fife like that, Please show me to do that.
Thank you.
Luan.
  • jwhend
    jwhend over 10 years ago
    You can use axlRunBatchDBProgram.
    You may need to put in the complete path to excel.exe
    --Jerry
  • luanvn81
    Hi Jerry!
    Thank for your reply, I have tried to set follow your advice but it still returm Error   'E- Unable to start program; excel
    Here my code:
       axlSpreadsheetWrite("Count_Via_By_Netlist.xls")
                axlSpreadsheetClose()
    axlRunBatchDBProgram("excel" "C:\Program Files (x86)\Microsoft Office\OFFICE11\excel.exe Count_Via_By_Netlist %s", ?reloadDB nil ?noUnload t)
    I'm really  not understand function axlRunBatchDBProgram clearly. please show me more.
    Tks.
    Luan.
  • eDave
    eDave over 10 years ago
    A really easy way to do this is to use axlHttp. ie axlHttp("Count_Via_By_Netlist.xls")
  • luanvn81
    Hi EDave!
    I have used function axlHttp () to open xls file, but not successful , it return nil. I don't know why, i think excel program have registered as  default web browser  in the Windows registry.
    Tks.
    Luan.
  • Kirti Sikri
    Kirti Sikri over 10 years ago
    If its a csv file delimited by same ,(comma) you want to open then you can open using regular file function infile, use gets to read lines from file as string and axlStringCSVParse to parse String as csv. Hope it helps
    For example if one has csv file,Book1.csv as following
    Instrument,CP,SP,Profit
    Keyboard,10.00 ,12.00 ,2.00
    Monitor,3.00 ,4.00 ,1.00
    Mouse,10.00 ,10.00 ,0.00
    Then Skill code to read the file and parse it as follows:
    csvFile = infile("Book1.csv") ; open the file for reading
    (while gets(curStr csvFile) ;gets reads a line from the input port and stores it as a string in a variable
    printf("curStr is %s\n" curStr)
    parsedStr=axlStringCSVParse(curStr) ;Parses a comma delimited line
    printf("parsedStr is %L count %d\n" parsedStr length(parsedStr))
    close(csvFile)
    Output of running the load the skill file is:
    Command > skill load "excel.il"
    curStr is Instrument,CP,SP,Profit
    parsedStr is ("Instrument" "CP" "SP" "Profit") count 4
    curStr is Keyboard,10.00 ,12.00 ,2.00
    parsedStr is ("Keyboard" "10.00 " "12.00 " "2.00 ") count 4
    curStr is Monitor,3.00 ,4.00 ,1.00
    parsedStr is ("Monitor" "3.00 " "4.00 " "1.00 ") count 4
    curStr is Mouse,10.00 ,10.00 ,0.00
    parsedStr is ("Mouse" "10.00 " "10.00 " "0.00 ") count 4
    Notes:
    gets reads a line from the input port and stores it as a string in a variable. The string is also returned as the value of gets. The terminating newline character of the line becomes the last character in the string. gets returns nil if EOF is encountered and the variable maintains its last value
    axlStringCSVParse(
    t_string
    [g_stripWhite]
    ) -> lt_string/nil
    Description
    Parses a comma delimited line (typical from Excel). This differs from the Skill prehistorian function in several areas which make it compatible with Excel csv file format:
    ■ parseString ignores two adjacent commas.
    ■ if a comma is contained within a cell, Excel quotes the cell. parseString treats this as
    two cells.
    ■ Correctly processes double quotes in a cell.
    Arguments
    t_string A csv string
    g_stripWhite Option to strip leading and trailing white space from each output
    string. Default is to leave whitespace.
    Value Returned
    lt_string list of strings parsed based on comma separator.
    nil error (unlikely to happen)
