  3. How to open .clp file in skill
  • Replies 11
  • Views 24340
KARPCB
KARPCB over 11 years ago
Hi all!
I need to run .clp file in skill. please let me know axl command for load .clp file
Karthik.K
  • B Bruekers
    B Bruekers over 11 years ago
    I just gave an example, standard.clp is what allegro uses as default.
    How is your CLP file called? Otherwise you need to give the full path to the file.  eg. load("c:/user/test.clp")
  • KARPCB
    I have changed my .clp name as standard. Also set the standard.clp file location into config->clippath. then i tried to load the clp file its shows error
  • KARPCB
    I thought path file will take from setup->user preprsnce editor->config->clippath.
    Now im able to load .clp file.
    Skill > _clpInit()
    t
    Skill > load("D:/working/clp/TI_Top.clp")
    Enter point
    last pick:  -4070.000 1260.000
     10 percent completed
     20 percent completed
     30 percent completed
     40 percent completed
     50 percent completed
     60 percent completed
     70 percent completed
     100 percent completed
    Thanks a lot.
  • B Bruekers
    You're welcome!
    btw, did you know that the .clp file is in fact a skill file?
    The "xx percent completed" are just some printf statements.
    Try this, just write some skill code and save the file as .clp.  Then do a file->import->subdrawing.
  • KARPCB
    You are Right!
    Really, Thanks for the valuable information.
