  3. How to read values from the list
  • Subscribers 159
  • Views 13798
KARPCB
KARPCB over 10 years ago
Hi all!
I have read all text attributes from my symbols using following skill Expression.
axlSetFindFilter(?enabled '("noall", "SYMBOLS"), ?onButtons '("SYMBOLS"))
axlAddSelectBox()
sym=axlGetSelSet()
axlClearSelSet()
foreach(one sym
chi = one->children
foreach(two chi
chi1 = two->text
printf("%L" chi1))))
* I have selected only two footprints J20 P12 *
CIW return value:
"6.5"".2559""5.54"".2181""2.54"".1000""RECOMMENDED BOARD THICKNESS 1.60 MM TO 2.40 MM""WIRE ENTRY SIDE""S160H110""C160H110""282834_2_2PIN-282834-2""J20""J20"nilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnilnil"LEAD LENGTH:2.41 MM""68000_X01_HDR-1P-68000-401HLF""C152H102_P08M08""P12""P12""P12"nilnilnilnilnilnilnilnilnil
From this texts(list) I need to read only recommended board thickness and lead length values. Anyone please show me to do that.
After reading those values I will give external value(real board thickness) through form field and compare the board thickness and lead length.
Karthik.K
  • eDave
    eDave over 10 years ago
    axlAddSelectBox()
    sym = axlGetSelSet()
    axlClearSelSet()
    foreach(one sym
    chi = one ->children
    foreach(two chi
    chi1 = two ->text
    when(index(chi1, "RECOMMENDED BOARD THICKNESS") || index(chi1, "LEAD LENGTH")
    printf("%s\n" chi1)
  • KARPCB
    Dave,
    I got error while loading.
    E- *Error* index: argument #1 should be a string (type template = "tS") - nil
    Actually, I need only the value of "RECOMMENDED BOARD THICKNESS" and "LEAD LENGTH"
    CIW return value :
    1.60 MM TO 2.40 MM
    2.41 MM
    -karthik.k
  • Kirti Sikri
    Kirti Sikri over 10 years ago
    That's because some ch1 are nil so when you try to index them you get that error. You can try checking for nil before indexing. New code is axlSetFindFilter(?enabled '("noall", "SYMBOLS"), ?onButtons '("SYMBOLS"))
    axlAddSelectBox()
    axlClearSelSet()
    foreach(one sym
    printf("chi is %L\n" chi)
    foreach(two chi
    chi1 = two ->text
    if(chi1 then
    printf("%s\n" chi1)
