  3. Deleting route Keepouts
  • Replies 19
  • Views 25666
FormerMember
FormerMember over 11 years ago
Hi All:
When we delete route keepouts it takes a long time.
The same time as if we were manually deleting then in Allegro.
How can this be sped up ?
Les
  • FormerMember
    We will try to delete in smaller groups
  • Junior0304
    Junior0304 over 11 years ago
    perhaps peeps already know, but i copied still(from cadence documentation) , since i need confirmation myself. Do not use axlDBCloak in these circumstances:
    *If you are adding or deleting non-connectivity database items (for example, loading many lines to a manufacturing layer)
    *If you need to interact with the user. Since connectivity is not updated, do not use the axlEnterXXX functions. Instead, get the information from the user first, then do the cloak update.
    *If you are reading the database, using cloak does not help and may actually slow performance.
    *If making a single change, using Cloak slows performance.
  • madboss
    madboss over 7 years ago in reply to FormerMember
    Hi les Wong , where to find Dyn clearance route keep out property in Allegro??
  • Gowtham229
    Gowtham229 over 7 years ago
    Hi Les,
    As dave told first thing is to make the shapes disbled so that it will not update shapes online which will be helpful for me most of times to improve tool performance. 2nd thing is DRC's should not be more than 5000 which could lead to slow up tool. Also subclass used in constraint regions should be only signal/plane layers not for all. 3rd thing delete unnececessary shapes/ dxf which will not be used to free up board memory
    if all the above wont work go with performance advisor which will suggest the reasons to improve allegro performance
    Gowtham
