  3. how to extract the FUNC_PHYSICAL_PATH in the report by using...
  • Subscribers 159
  • Views 12622
how to extract the FUNC_PHYSICAL_PATH in the report by using skill file?
chloe
chloe over 10 years ago
I download a skill file that can generate the component height information
But i would like to modify the skill by adding the "FUNC_PHYSICAL_PATH" in the report
Here is the skill file that i downloaded
axlCmdRegister("height_rep" '_extract_report ?cmdType "general")
defun( _extract_report ()
let(list(last_line extract_commands extract_data report_file cmd_file ext_results f_report l_fields)
last_line = ""
extract_commands = "_tmp_extract.txt" ;name of temp extract command file
extract_data = "_tmp_extract.dat"
report_file = "comp_height_report"
;Create the extract command file
cmd_file = outfile(extract_commands)
fprintf(cmd_file "GEOMETRY\n")
fprintf(cmd_file "REFDES!=\"\"\n")
fprintf(cmd_file "COMP_DEVICE_TYPE!=\"\"\n")
fprintf(cmd_file "CLASS = \"PACKAGE GEOMETRY\"\n")
fprintf(cmd_file "SUBCLASS=\"PLACE_BOUND_TOP\"\n")
fprintf(cmd_file "OR\n")
fprintf(cmd_file "SUBCLASS=\"PLACE_BOUND_BOTTOM\"\n")
fprintf(cmd_file "REFDES\n")
fprintf(cmd_file "COMP_DEVICE_TYPE\n")
fprintf(cmd_file "GRAPHIC_DATA_NAME\n")
fprintf(cmd_file "SUBCLASS\n")
fprintf(cmd_file "GEO_PACKAGE_HEIGHT_MAX\n")
fprintf(cmd_file "GEO_PACKAGE_HEIGHT_MIN\n")
close(cmd_file)
axlExtractToFile(extract_commands extract_data '("quiet"))
ext_results = infile(extract_data)
f_report = axlDMOpenFile("ALLEGRO_REPORT" report_file "w")
while( gets(line_rd ext_results)
l_fields=parseString(line_rd "!")
if(car(l_fields)=="S" then
unless(last_line==line_rd
;unless the line read matches the last line write it to the report.
fprintf(f_report "%s", line_rd)
last_line=line_rd ;reset the last line value
);end unless
);end if
);end while
close(ext_results)
close(f_report)
;Clean up
deleteFile(extract_commands) ;delete the view file
deleteFile(extract_data) ;delete the raw data file
printf("Report complete.\n")
);end let
);end defun
May i know how to add this "FUNC_PHYSICAL_PATH" to include the components physical path in the report?
