  3. axlSetFindFilter with Nameform.
  • Subscribers 159
  • Views 13271
luanvn81
luanvn81 over 10 years ago
Hi All!
            I'm writing a code using function axlSetFindFilter with keyword "NAMEFORM" to load net by list. I have a list of nets with some nets that is not exist in brd data, when loading netlist using "NAMEFORM", how to know how many nets are loaded & how many nets load failed?.
Tks.
Luan
  • B Bruekers
    B Bruekers over 10 years ago
    Is there a reason why you want to use axlSetFindFilter for this?
    If you have a list of nets you can compare them with this list: axlDBGetDesign()~>nets~>name
    for example;
    l_netcheck = '("GND" "3V3" )
    l_netdesign = axlDBGetDesign()~>nets~>name
    foreach(net l_netcheck if(member(net l_netdesign ) then pprint("found") else pprint("Not found")))
    The pprints you can change into this to store the nets in a list:
    l_found = l_notfound = nil
    foreach(net l_netcheck if(member(net l_netdesign ) then l_found = cons(net l_found) else l_notfound = cons(net l_notfound) ))
