  3. How to set up to use SKILL?
  • Replies 7
  • Subscribers 166
  • Views 26059
tmd63
tmd63 over 10 years ago
I have some skill file examples but I cannot access them. These are the examples in toolbox.
But we have a different environment setup so I dont think the toolbox is step up to run.
If I try and type 'tbx changewidth' for example. I get an error message 'E - Command not found'. These are the examples found in share\pcb\toolbox\ but the path to start does not appear to be set.
Where is the path for using SKILL commands found?
  • B Bruekers
    B Bruekers over 10 years ago
    The "colorTest" in the axlFormCreate function is pointing to a form file found in the form path(s).
    You need to check your form path settings, and see if the 'colorTest.form" is located in one of these form paths.
    If you use a complete file path it works without any other settings:
    form = axlFormCreate('ct "C:/Cadence/SPB_16.6/share/pcb/examples/skill/form/color/colorTest.form" nil 'colorTestDispatch t)
  • jwhend
    jwhend over 10 years ago
    Go to Setup->User Preferences
    In the search box put "form" the search results will show "formpath"
    Select the browser box and make sure the path includes the location of the .form file.
    If you have the form file in your working directory, make sure the path starts with "."
    When you start creating your own skill programs you may want to create the forms on the fly, that way you do not have to maintain a directory of form files.
    --Jerry
