  3. Utility to output a single symbol from a design
  • Replies 7
  • Subscribers 167
  • Views 19406
joma
joma over 9 years ago
https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/28/jm_5F00_write_5F00_1_5F00_symbol_5F00_public.zip
Hi, I recently discovered the skill command "axlWritePackageFile( car(axlSelectByName("SYMTYPE" symbol-name))->definition )" which writes a single footprint
from a pcb. The good thing about it is it writes the symbol .dra and.psm files with all associated padstack files. I find this very handy from time to time. The bad thing
is it is a pain to be typing skill commands like this so I have created a user interface form to make things easier. As I have benefited from lots of utilities found in this
forum I thought I would contribute something of my own (however simple).
To load the code type "skill load("jm_write_1_symbol_public.il"). The file shoud be in your skill path.
To run the code type "write one symbol" on the command line.
All feedback welcome.
Load the Skill code using"skill load("RotateSilkAssyRD.il)" - See more at: community.cadence.com/.../17911
  • JCTEYSSIER0
    JCTEYSSIER0 over 1 year ago in reply to YH202508126436
    Allegro stores the symbol definiton as you read it from library. This is this version that is exported.
    Even if you can modify an instance of this package but have no effect on source stored one.
    Furthermore, you can modify an instance a way (say, change line width de 0.3mm) and an other instance oher way (say change line width to 0.05mm) BUT this is only on concerned instance.
  • John T
    John T over 1 year ago
    For anyone with the "Productivity Toolbox" license option, please know that you can do this directly from the Editor using menu Tools > Quick Symbol Edit. In the options panel you can now select from the presented list of database symbols; then just hit the "Export Only" Button. This will export this symbol and its pads to your folder of choice.
