  3. Creating a Via Matrix Using Skill
  • Views 18332
Kevinko
Kevinko over 9 years ago
I know that there is an option that lets you create a Via Matrix, but I want to know how that is done programmatically. I noticed that if you try placing via by via in a board it takes a lot of time.. e.g.create vias from (0,0) to (500,600) with a distance of 100 between them. This takes more time than it should if you have to create more vias, but the option to create a via matrix does it 10 times faster.
I'm currently using this method: axlDBCreateVia(padstack x:y)
Any Information or help will be appreciated.
Thank you!
  • Kevinko
    Thank you!! Worked perfectly.
