  3. How to color a string using SKill
  • Replies 11
  • Subscribers 159
  • Views 20308
JerryWilson
JerryWilson over 8 years ago
Hi Dave, all
I have a code to check footprint prints in our library. In my code i will output it into a log file called MCL log file.
In the code i have pass/fail messages in which for pass messages, i want to color it green & fail message as red.
How do i do that. Below is a portion of the code.Hope anyone can help.
JerryWilson
defun( _mcl_start ()
let((errors overallerrors)
overallerrors=0
mcl_log.log=axlDMOpenLog("mcl")
fprintf(mcl_log.log " MCL CHECK LOG ............................... Created:")
Date=(getCurrentTime)
fprintf(mcl_log.log "%s\n\n" Date)
axlDBGetDesignUnits()
fprintf(mcl_log.log "\n-----------------------------CHECK DRAWING PARAMETERS----------------------------\n")
errors=0
let((y m p)
y = axlGetParam('paramDesign)
if(y->units=="millimeters" then
;fprintf(mcl_log.log "\nPASSED :USER UNITS." )
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID USER UNITS., %s" y->units)
if(y->accuracy==3 then
;fprintf(mcl_log.log "\nPASSED :ACCURACY." )
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID ACCURACY., %d" y->accuracy)
if(y->height==210 then
;fprintf(mcl_log.log "\nPASSED :DRAWING EXTENT HEIGHT." )
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID DRAWING EXTENT HEIIGHT., %f" y->height)
if(y->width==297 then
;fprintf(mcl_log.log "\nPASSED :DRAWING EXTENT WIDTH." )
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID DRAWING EXTENT WIDTH., %f" y->width)
if(y->xy==list(-150 -105) then
;fprintf(mcl_log.log "\nPASSED :DRAWING EXTENT LOWER X AND LOWER Y." )
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID DRAWING EXTENT LOWER X AND LOWER Y., %P\n" y->xy)
m = axlDesignType(t)
if( or( m=="PACKAGE" m=="SHAPE" m=="FLASH" ) then
;fprintf(mcl_log.log "\nPASSED :SYMBOL TYPE., %s\n" m)
else
errors++
overallerrors++
fprintf(mcl_log.log "\nFAILED :INVALID SYMBOL TYPE., %s\n" m)
if(errors==0 then
fprintf(mcl_log.log "\n\t%d ERROR(S) ON DRAWING PARAMETERS SETTINGS.\n", errors)
else
fprintf(mcl_log.log "\n\t%d ERROR(S) ON DRAWING PARAMETERS SETTINGS\n", errors)
;fprintf(mcl_log.log "***CHECK DRAWING PARAMETERS-END*****\n\n")
  • eDave
    eDave over 8 years ago
    Hi Jerry,
    Just add the following line at the start:
    <!DOCTYPE html>
  • eDave
    Some of the codes have changed in 17.2. I have raised a case asking for some documentation.
    <b> no longer works for bold. Try <h1>, <h2> etc for headings, <u> for underline.
  • JerryWilson
    Hi Dave
    I tried to add <!DOCTYPE html>, below is the output.It s not red.
    MCL CHECK LOG ............................... Created:Aug 16 05:40:53 2017
    <!DOCTYPE html><font color="red">
    FAILED :INVALID ACCURACY., 4 </font></b>
    i added it at the start, as per below. Do i need to add anywhere else or am missing something here.?
    fprintf(M, "<!DOCTYPE html><font color=\"red\">\nFAILED :INVALID ACCURACY., %d </font></b>\n" y->accuracy)
    I did a few testing on the code you provided earlier, to my surprise it works & the bold works too. Below is the code i tested. Below 2 codes works perfectly in 17.2. I cant figure out what is going on as what you earlier claimed that bold is not working, below 2 codes was able to bold the text. Please help.
    defun( _testHTML1 ()
    let((p)
    p = axlDMOpenLog("aaa")
    when(p
    ;fprintf(p, "The quick brown fox at (0.0 0.0) ...<Br>\n")
    fprintf(p, "<font color=\"red\">This is red text.</font>\n")
    fprintf(p, "<b><font color=\"red\">\nFAILED :HEADER WITH CORRECT DATA ELEMENT BUT INCORRECT DATA TYPE.</font><b>")
    fprintf(p, "<b><font color=\"red\">\nFAILED :INVALID DRAWING EXTENT HEIIGHT.</font><b>")
    drain(p)
    axlDMClose(p)
    axlUIViewFileCreate("aaa.log", "Sample2", nil)
    defun( _testHTML ()
    let((p)
    p = axlDMOpenFile("ALLEGRO_HTML", "aaa.log", "w")
    when(p
    ;fprintf(p, "<!DOCTYPE html>\n")
    ;fprintf(p, "<html>\n")
    fprintf(p, "<body>\n")
    fprintf(p, "The quick brown ...<Br>\n")
    ;fprintf(p, "</body>\n")
    ;fprintf(p, "</html>\n")
    ;drain(p)
    axlDMClose(p)
    axlUIViewFileCreate("aaa.log", "Sample", nil)
  • eDave
    I see varying results. It may be my eyes but I don't see bolding in 17.2.
    It appears that the interpretation of HTML content just requires the first character of the text file to be a "<" in 17.2.
    I'm still waiting for a response to my service request.
    16.6:
    17.2:
    defun( testHTML2 ()
    let((p)
    when(p
    ;fprintf(p, "<>The quick brown fox at (0.0 0.0) ...\n")
    fprintf(p, "<font color=\"red\">FAILED :HEADER WITH CORRECT DATA ELEMENT BUT INCORRECT DATA TYPE.</font>\n")
    fprintf(p, "<b><font color=\"red\">FAILED :HEADER WITH CORRECT DATA ELEMENT BUT INCORRECT DATA TYPE. (BOLD)</font></b>\n")
    fprintf(p, "<font color=\"green\">This is green text.</font>\n")
    fprintf(p, "<b><font color=\"green\">This is bold green text.</font></b>\n")
    fprintf(p, "<b><font color=\"red\">This is bold red text.</font></b>\n")
    fprintf(p, "<font color=\"red\">This is red text</font>\n")
    drain(p)
    axlDMClose(p)
  • JerryWilson
    Hi Dave
    I have manged to add the command in my code. However as what you said the bold is not working. Please keep me posted on the updated bold command. I also found out that the tracef(t) command is not working in 17.2. Its giving a warning. Do you have any idea if the trace command is being updated?
    W- *WARNING* Setting trace to 't' is not permitted as it could cause severe performance degradation during SKILL evaluation. To disable this check, type sstatus( traceTEnable t ) in the CIW.
    Jerry
