  3. Ask for help about the check pad/via overlap with the t...
  • Subscribers 159
  • Views 3433
Ask for help about the check pad/via overlap with the text
jancho
jancho over 6 years ago
Hi all , now I have wrote a code to check if the pad/via overlap with the text ,but it always return"Total of text on TOP pad:0"
Could you help to check and give some advice, thanks in advance!
Code shown as following:
(defun refdes_on_pad ()
text_pad = t
layer = "TOP"
turn_on_layer(layer)
unselect_object()
axlSetFindFilter(?enabled '(noall pins vias) ?onButtons '(noall pins vias))
allpads = axlGetSelSet(axlAddSelectAll())
if(text_pad then
cnt = 0
foreach(pads allpads overlap())
axlMsgPut("Total of text on %s pad : %d" layer cnt)
(defun getpadarea ()
(prog ()
l0 = car(nth(0 pads->bBox))
t0 = cadr(nth(1 pads->bBox))
r0 = car(nth(1 pads->bBox))
b0 = cadr(nth(0 pads->bBox))
x0 = (r0+l0)/2
y0 = (t0+b0)/2
padsold=axlDBGetPad(pads , "PIN/SOLDERMASK_TOP" , "REGULAR")->bBox
padetch=axlDBGetPad(pads , "ETCH/TOP" , "REGULAR")->bBox
ls = car(nth(0 padsold))
ts = cadr(nth(1 padsold))
rs = car(nth(1 padsold))
bs = cadr(nth(0 padsold))
le = car(nth(0 padetch))
te = cadr(nth(1 padetch))
re = car(nth(1 padetch))
be = cadr(nth(0 padetch))
xs = (rs-ls)/2
ys = (ts-bs)/2
xe = (re-le)/2
ye = (te-be)/2
if(xe>xs then
xfinal=xe
yfinal=ye
else
xfinal=xs
yfinal=ys)
l2 = x0-xfinal
t2 = y0+yfinal
r2 = x0+xfinal
b2 = y0-yfinal)
return(list(l2:t2 r2:b2)))
(defun overlap ()
(prog ()
axlSetFindFilter(?enabled '(noall text) ?onButtons '(noall text))
if(axlSingleSelectBox(getpadarea())!= nil then
allbox = axlGetSelSet()
foreach(item allbox
if(item->objType == "text" then
if(item->layer ==strcat("REF DES/SILKSCREEN_" layer)|| item->layer == strcat( "PACKAGE GEOMETRY/SILKSCREEN_" layer) then
axlHighlightObject(list(item))
else nil
(defun unselect_object ()
(let (allsel)
axlSetFindFilter(?enabled '(noall shapes pins vias text) ?onButtons '(noall shapes pins vias text))
; axlSetFindFilter(?enabled '(all) ?onButtons '(all))
allsel = axlGetSelSet(axlAddSelectAll())
axlClearSelSet()
axlSetFindFilter(?enabled '(noall symbols) ?onButtons '(noall symbols))
axlClearSelSet()
(defun turn_on_layer ( layer)
axlVisibleDesign(nil)
Going_On=axlGetParam("paramLayerGroup:BOARD GEOMETRY/paramLayer:OUTLINE")
Going_On->visible=t
axlSetParam(Going_On)
Going_On=axlGetParam(sprintf(dummy "paramLayerGroup:VIA CLASS/paramLayer:%s" layer))
if(layer == "BOTTOM" then
Going_On->visible=t
else
Going_On->visible=nil
Going_On=axlGetParam(sprintf(dummy "paramLayerGroup:PIN/paramLayer:%s" layer))
Going_On->visible=t
Going_On=axlGetParam(sprintf(dummy "paramLayerGroup:PACKAGE GEOMETRY/paramLayer:SILKSCREEN_%s" layer))
Going_On->visible=t
Going_On=axlGetParam(sprintf(dummy "paramLayerGroup:REF DES/paramLayer:SILKSCREEN_%s" layer))
Going_On->visible=t
Going_On=axlGetParam(sprintf(dummy "paramLayerGroup:PACKAGE GEOMETRY/paramLayer:PLACE_BOUND_%s" layer))
Going_On->visible =t
axlUIWRedraw(nil)
axlClearSelSet()
  • jancho
    My idea is as following:
    first get the bBox of pin/via ,then judge if the regular pad or solder is bigger , then judge if  the bigger bBox area exist a text , if have text , then highlight the text.
  • eDave
    eDave over 6 years ago in reply to jancho
    Whatever else this code is doing, cnt isn't being incremented.
    Add cnt++ before or after axlHighlightObject
  • jancho
    jancho over 6 years ago in reply to eDave
    Thank you eDave! This is my mistake.
    There seems also have other wrong place.When code run finished , return "Total of text on TOP pad:0" , and all pin/via highlighted.
  • DavidJHutchins
    DavidJHutchins over 6 years ago in reply to jancho
    I ran your code thru the checking utility sklint & corrected the issues it found, corrected a couple of logic issues and added a couple of debug printing statements, please try using the updated code shown below:
    procedure(refdes_on_pad()
    let((text_pad layer cnt tmp allpads)
    (text_pad = t)
    (layer = "TOP")
    unselect_object()
    (axlSetFindFilter ?enabled '(noall pins vias) ?onButtons '(noall pins vias))
    (allpads = (axlGetSelSet (axlAddSelectAll)))
    axlMsgPut(";; total pin cnt %d" length(allpads))
    if(text_pad then
    (cnt = 0)
    foreach(pad allpads
    (tmp = text_overlap(pad layer))
    (cnt = (cnt + tmp))
    (axlMsgPut "Total of text on %s pad : %d" layer cnt)
    procedure(getpadarea(pads)
    prog((l0 t0 r0 b0 x0 y0 padsold padetch ls ts rs bs le te re be xs ys xe ye xfinal yfinal l2 t2 r2 b2)
    (l0 = car(nth(0 (pads->bBox))))
    (t0 = cadr(nth(1 (pads->bBox))))
    (r0 = car(nth(1 (pads->bBox))))
    (b0 = cadr(nth(0 (pads->bBox))))
    (x0 = ((r0 + l0) / 2))
    (y0 = ((t0 + b0) / 2))
    (padsold = ((axlDBGetPad pads "PIN/SOLDERMASK_TOP" "REGULAR")->bBox))
    (padetch = ((axlDBGetPad pads "ETCH/TOP" "REGULAR")->bBox))
    (ls = car(nth(0 padsold)))
    (ts = cadr(nth(1 padsold)))
    (rs = car(nth(1 padsold)))
    (bs = cadr(nth(0 padsold)))
    (le = car(nth(0 padetch)))
    (te = cadr(nth(1 padetch)))
    (re = car(nth(1 padetch)))
    (be = cadr(nth(0 padetch)))
    (xs = ((rs - ls) / 2))
    (ys = ((ts - bs) / 2))
    (xe = ((re - le) / 2))
    (ye = ((te - be) / 2))
    if((xe > xs) then
    (xfinal = xe)
    (yfinal = ye)
    else
    (xfinal = xs)
    (yfinal = ys)
    (l2 = (x0 - xfinal))
    (t2 = (y0 + yfinal))
    (r2 = (x0 + xfinal))
    (b2 = (y0 - yfinal))
    return(list((l2:t2) (r2:b2)))
    procedure(text_overlap(pad layer)
    prog((allbox cnt)
    (cnt = 0)
    (axlSetFindFilter ?enabled '(noall text) ?onButtons '(noall text))
    when((axlSingleSelectBox getpadarea(pad))
    axlMsgPut(";; %d text found near pad @ (%f %f)" length(axlGetSelSet()) xCoord(pad->xy) yCoord(pad->xy))
    (allbox = (axlGetSelSet))
    foreach(item allbox
    if(((item->objType) == "text") then
    when((((item->layer) == strcat("REF DES/SILKSCREEN_" layer)) || ((item->layer) == strcat("PACKAGE GEOMETRY/SILKSCREEN_" layer)))
    (axlHighlightObject list(item))
    (cnt++)
    return(cnt)
    procedure(unselect_object()
    let((allsel)
    (axlSetFindFilter ?enabled '(noall shapes pins vias text) ?onButtons '(noall shapes pins vias text))
    (allsel = (axlGetSelSet (axlAddSelectAll)))
    (axlClearSelSet)
    (axlSetFindFilter ?enabled '(noall symbols) ?onButtons '(noall symbols))
    (axlClearSelSet)
    procedure(turn_on_layer(layer)
    let((Going_On)
    (axlVisibleDesign nil)
    (Going_On = (axlGetParam "paramLayerGroup:BOARD GEOMETRY/paramLayer:OUTLINE"))
    (Going_On->visible = t)
    (axlSetParam Going_On)
    (Going_On = (axlGetParam sprintf(nil "paramLayerGroup:VIA CLASS/paramLayer:%s" layer)))
    if((layer == "BOTTOM") then
    else
    (Going_On->visible = nil)
    (Going_On = (axlGetParam sprintf(nil "paramLayerGroup:PIN/paramLayer:%s" layer)))
    (Going_On = (axlGetParam sprintf(nil "paramLayerGroup:PACKAGE GEOMETRY/paramLayer:SILKSCREEN_%s" layer)))
    (Going_On = (axlGetParam sprintf(nil "paramLayerGroup:REF DES/paramLayer:SILKSCREEN_%s" layer)))
    (Going_On = (axlGetParam sprintf(nil "paramLayerGroup:PACKAGE GEOMETRY/paramLayer:PLACE_BOUND_%s" layer)))
    (axlUIWRedraw nil)
    (axlClearSelSet)
  • jancho
    jancho over 6 years ago in reply to DavidJHutchins
    Thanks David! Thanks for your kindly help! Now it worked, amazing!
