  3. Export Fab notes as a text file
  • Replies 11
  • Subscribers 166
  • Views 23299
HSID
HSID over 6 years ago
I would like to be able to copy my fab notes from my database and export as a .txt file.
This way my board house can easily edit the notes to their specifications and hopefully I could import in their modified text file
  • joma
    joma over 6 years ago
    You could try a simple utility I wrote. Unzip the attached file in the pcb directory of your board.
    In allegro command window type
    load("./st_output_text.il")
    Then type output_text, select your text (use Temp group if needed). Then save the file.
    (I uploaded the file by drag and drop but can't see any obvious result. If there is a problem let me know.)
    Jim O'Mahony
  • joma
    joma over 6 years ago in reply to joma
    Ok it has to be a .zip and not .7z
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/27/6253.st_5F00_output_5F00_text.zip
  • HSID
    HSID over 6 years ago in reply to joma
    I tried typing in the command you list above and always receive a command not found message in the command prompt.
    I stored the zip file and extracted the file within to my working directory
    I typed in load(".lst_output_text.il") is this correct?
  • joma
    joma over 6 years ago in reply to HSID
    Sorry, 'load' is a skill command so just copy and paste this command:
     skill load("st_output_text.il")
    The ./  (dot slash) is not strictly necessary if the file is in the pcb directory.
  • DavidJHutchins
    DavidJHutchins over 6 years ago
    I made some modifications to the skill code so the output text is sorted to match the layout locations, the attached zip file contains the updated skill code
    https://community.cadence.com/cfs-file/__key/communityserver-discussions-components-files/27/4503.st_5F00_output_5F00_text.zip
