  3. Compare the database footprint with library footprint -...
  • Replies 10
  • Subscribers 168
  • Views 13473
Compare the database footprint with library footprint -Skill
pradeep4321
pradeep4321 over 6 years ago
I would like to generate the comparison report of database footprint with library footprint if any mismatch available.
Is there a way to take if it possible means can anyone please guide me or share me the skill code please.
Pradeep
  • B Bruekers
    B Bruekers over 6 years ago in reply to EvanShultz +1
    I've ever implemented such timestamp check, but it is far from fail-safe. There are possible differences of 1-10 seconds (PSM filetimestamp =! version_id), and even 3600s if you are lucky. The biggest…
  • EvanShultz
    EvanShultz over 6 years ago in reply to EvanShultz +1
    I was stupidly looking at the components and compdef list, when I should have been looking at symbols and symdef list. Each symdef has the following properties: VERSION_ID and LIBRARY_PATH. Those have…
  • B Bruekers
    This biggest issue with the footprint mechanism of Cadence is that the padstack figure data is not taken from the PSM but from the actual padstack files. You can test this, t ry to place a PSM file without…
  • EvanShultz
    EvanShultz over 6 years ago in reply to B Bruekers
    Has anybody seen inconsistent results with fileTimeModified()?
    Using timeToString(fileTimeModified(axlOSSlash(<valid path to PSM file>))) I see some results match between all computers and some have an off-by-one-hour issue. I suspect it's due to daylight savings time here in the US, but I can't figure it out. The actual file save date is correctly returned on some PCs for a file saved in August, and on others the returned value is one _exactly_ one hour later.
  • EvanShultz
    EvanShultz over 5 years ago in reply to EvanShultz
    It turns out that the different is 17.2 vs 17.4. 17.4 appears to have fixed the issue. However, Cadence no longer provides a list of functions that were changed (or added or new) with each Allegro version and they tell me there's no change, no it's a mystery. Certainly the support answer of no change does not reconcile with my experience running the functions on the same PC and getting different results under 17.2 and 17.4...
  • emldebh61
    emldebh61 over 4 years ago in reply to B Bruekers
    HI Is it possible to share this code at all, Thanks
  • AvengerThanos
    AvengerThanos over 4 years ago
    If cadence could come up with a utility to find differences in footprints it would be much helpful to PCB designers since the updates could happen often sometimes. There was an earlier post too that requested a solution for the same question.
  • mstaub
    mstaub over 4 years ago
    We use a text field and property to manage the version of the symbol. Using Skill you can easily compare the version of the symbol placed in a design to what is currently in the library.
    Using Dal Tools also provides a much more detailed list of what the differences are, which can sometimes be too much detail to what you're actually looking for.
