  3. FlexId and Windows 10 May 2020 Update (v 2004)
  • Replies 7
  • Subscribers 167
  • Views 33900
csoon1
csoon1 over 6 years ago
Software: ORCAD PCB Designer Professional
Version: 17.2 S063
Overview:
When I installed my ORCAD on a Windows 10 computer a while back, every time I run the Cadence License Server Configuration (when I swap USB dongle/license... because our company has a few), I always get this message at the very last step:
"Cadence License Server Configuration utility has detected that it needs to install the FLEXid 9 dongle driver on your system. Please make sure to connect your FLEXid USB dongle to an available USB port. The driver installation process may take a few minutes. Click OK to continue or Cancel to terminate the Cadence License Server Configuration utility"
I always click "OK" and it does its thing... long wait... and it gives the message below (which I always ignore because at the end the license/dongle still work as intended and the software is usable).
"- Unable to restart Cadence License Server with the new license file "..... ". Failed to install FLEXid dongle driver. Failed to update your CDS_LIC_FILE license path with the new license server setting "....".
Like I said above, though it shows the above message, everything still works as intended. The FLEXID information is correctly shown on the System Settings at LMTOOLS and the license service works.
Fast forward... June 2020, I installed the same software on a new computer I recently assembled running on the latest Windows 10 update. I went through the above License Server configuration process and when it got to the step where it says that the FLEXid 9 dongle driver needs to be installed, I clicked "OK" as usual. However this time after just a few seconds of clicking "OK", the system rebooted. This process is repeatable and the system will just reboot at this step on the process. The FLEXID information is blank on the System Settings at LMTOOLS which gives me the impression that the dongle is not installed and the information from it could not be retrieved.
After a series of long frustrating trial-and-error and numerous reboots, my computer finally gave up and showed Blue Screen of Death (BSOD). It referenced an error "PAGE_FAULT_IN_NONPAGED_AREA" related to the file "aksdf.sys". Now the more annoying thing is that my computer is now going to an endless loop of BSOD showing that issue. I did some Googling at it seems like the latest Windows 10 May 2020 update (version 2004) has some issues with this file.
Further Googling, this file is described as "The genuine aksdf.sys file is a software component of Aladdin HASP by Aladdin Knowledge Systems. Aladdin HASP (Hardware Against Software Piracy) a digital rights management (DRM) suite of protection and licensing software. Aksdf.sys is a filter driver that is necessary for the proper functioning of HASP. The component adds support for specialized external devices. Removing this file may cause problems with Aladdin hardware." It seems like Flexera is using this.
Have any of you experienced this? I really need some technical advice on how to deal with this issue so that I can install this software on the new machine.
  • echev
    echev over 5 years ago in reply to MaximP
    For my case we downloaded driver compliant with our USB dongle (based on what is printed on dongle), we installed it and it makes it work!
    Best regards,
  • MaximP
    MaximP over 5 years ago in reply to echev
    Thanks for replying. I had a blue screen even without dongle being connected to usb :(
