  3. How to make copper pour on a layer if PCB Editor crashes...
  • Replies 15
  • Views 24428
How to make copper pour on a layer if PCB Editor crashes every time I try to place a shape?
olebon
olebon over 6 years ago
I have a strange problem with the PCB editor - it crashes with no diagnostic if I place any shape (except for imported netlist parts). In the same time I finished routing and need to finalize it with flooding copper to the layers and planes. I tried to ask for support, all they were able to suggest is install latest revision and run database check. I guess somebody had this or a similar issue before? Please help!
Buying ORCAD was such an awful mistake :(
  • excellon1
    excellon1 over 6 years ago in reply to olebon
    Well maybe a different approach will get you to where you need to be. When it comes to creating more complex geometry Allegro is certainly up to the task but the first thing and the easier road to go is to actually draw what you want. For the moment don't worry about keepouts or board outlines or any of that stuff. The key is how to draw the actual geometry of what you want.
    So how to do that.
    With a fresh board go to "Add a Line" on the tool bar and draw the top part of your cut out to be that size. Down in the bottom of the screen you will see the coordinates displayed, cycle to R mode which is relative so you can see how far you had drawn the line. You can place the line on the following Class Subclass - "Board Geometry - Silkscreen top", In the picture below those lines are 1200 Mil which is close to 30.4 mm. (Still use Imperial units in the USA) Slight smile
    Ok the next part is how to draw the circle so to do that we go to the tool bar and choose "Add - 3PT ARC" In the picture above Left click on top the upper right side line and draw a line left. When you get to the top left line, left click then drag the mouse down. You will see the circle start to appear. Drag down until you reach the desired size of your circle. From your earlier picture I made the circle in the pic below to be 3000Mil or 66mm.
    So with this basic geometry you have a great starting point. From here you will have to figure out how to get that geometry converted to be a board outline and keepout etc. That part is not that hard really. Maybe you can figure it out but if not I can show you how.
    BTW if Orcad is still crashing on you, You should call support. It is plausible that your whole design could well be corrupt.
    All the best.
  • olebon
    olebon over 6 years ago in reply to steve
    Thank you Steve. This is what happens if I try ZCopy:
    First, unlike what they show in tutorials, left top area is ignored for some reason. Second, even if I try to use keepin without top left part, if I attempt to place a circular shape (even a small one within keepin bordes) ORCAD crashes, this time with some obscure message.
    The most important the customer support agreed that there is a bug, but I have no idea if it will ever be fixed.
  • olebon
    olebon over 6 years ago in reply to excellon1
    Thanks, I just typed a reply that was lost somehow. I followed the instruction, however there is one small detail I cannot fix: after I drawn the shape on the silkscreen it appears to be a set of separate shapes, even though I entered all point values manually, i.e. en of one line is explicitly set to be start of the next one and same for the arc. Is there a way to combine them into a single shape to avoid message "Not a closed polygon"?
  • excellon1
    Ok then we are down to the last part. Getting there eh :)
    So a couple of things. You are correct in that if you draw lines etc that the geometry will not be closed but this is ok because we will use this geometry to create what we need. In Allegro shapes are really powerful more so than any other PCB tool I have seen. Basically you can make shapes directly or indirectly using lines as the basis.
    So to refresh we have the geometry we need and we put this geometry on a layer that is the "Board Geometry - Silkscreen Top", we could have put it on another layer too. The idea is just to get what we needed drawn first.
    Here is what we have again for clarity just to refresh.
    Next we want to convert this geometry to a "Board Outline" & also a package keep in & a route keep in.
    In your find filter make sure both Lines & shapes are checked.
    1 Go to the tool bar and choose the shapes menu and select "Compose a Shape"  - On the right hand side options panel you should see something similar to the pic. Notice that the options default to etch which is ok as we will change the options to suit.
    Here is a pic:
    Change the options to:
    Active Class "Board Geometry" - Add shape to sub class Outline, I'm using 16.6 so I use outline which is the board outline. In 17.4 you would choose Design Outline I believe.
    Another Pic:
    Lastly with your mouse left click and hold the left mouse button down on the canvas and draw a box to encompass the geometry. The geometry will highlight, Right click and select done.
    You now have created your "Board Outline"
    Here is another pic of the completed Board Outline.
    So that's very cool & when you get used to the mechanics of things you can see the potential this actually has for creating very complex shapes or board outlines etc. Lots of possibilities exist .
    In Allegro you can Compose shapes from lines & also decompose shapes to lines.
    Ok then down to the final bits. You still have to create your Route Keepin & also your package keepin. I f you turn off the Board Outline layer in the options panel you will see you still have your original geometry on the board outline silkscreen top layer so you can re-use this original geometry to make the additional Route Keepins and Package keepins you need by doing the same process again.
    When you create the additional items they will be the exact same size as the original geometry. When you get the last items made a good rule of thumb is to back them off from the board outline by say 50 Mil OR 100 Mil, this will be easy to do as Allegro gives you the ability to Shrink or expand shapes.
    Basically what you do is select the shape - say Route Keepin all and right click and choose Expand/Contract, reduce the shape by the amount you need using the buttons in the options panel.
    Here is a pic showing the route keepin reduced by 100 mils.
    After all is complete you can delete your original geometry from the Board Geometry - Silkscreen top layer.
    BTW there is another way to do this that kind of speeds up the operation too.
    All the best
  • olebon
    The support suggested a workaround for this bug. The problem disappears if Design accuracy is set 2 and it really worked.
