  3. (SPMHFN-24): Application can not mix select modes.
  • Subscribers 160
  • Views 13500
leto
leto over 5 years ago
Hello All,
I get this error "(SPMHFN-24): Application can not mix select modes." when running a 'axl select' command.
May I know which axl command to use to exit from the current mode or to select/switch to another mode?
Thanks All
  • FoCo
    FoCo over 2 years ago
    I get this issue as well if a script doesn't finish well.  When this happens, you can't select objects using the normal interface.  The only option to keep editing the database I have found is to reopen the design.  Changing from General Edit mode to other modes doesn't do anything.
  • DavidJHutchins
    DavidJHutchins over 2 years ago in reply to FoCo
    I encountered this issue when developing some skill code, I solved it by adding the following to the beginning of the code:
    (AppMode = axlUIAppMode('mode))
    when(stringp(AppMode)
        axlUIAppMode('none)
    and the following at the end:
        axlUIAppMode('set AppMode)
