  3. Copy Net class from Physical to Electrical
  • Replies 8
  • Subscribers 166
  • Views 18780
Lennie
Lennie over 6 years ago
How do you copy a netclass from the Physical Tab to Electrical Tab  ?
  • Lennie
    Lennie over 6 years ago in reply to redwire
    There are many ways to do this but for me I need the same classes in both physical and electrical. Certain classes that need matched length also have different physical and spacing rules. All I was asking if there was a way to copy the classes for physical to electrical without having to re-enter them. I guess the answer is no.
  • mcatramb91
    mcatramb91 over 6 years ago
    I don't have an easy way to copy the Net Class from Physical to Electrical but I do have a suggestion.
    If you use a Net Group to group the nets it will be seen across Physical, Spacing and Electrical worksheets.
    In the Physical or Spacing worksheet, you can add the Net Group to a Class when required. (Hover over Net Group name and RMB > Create > Class)
    Hope this helps,
    Mike Catrambone
  • Lennie
    Lennie over 6 years ago in reply to mcatramb91
    Thanks Mike,
    I will try that the next time. !
