  3. well tested 0201 symbol footprint
  • Replies 12
  • Subscribers 166
  • Views 24767
frank mpbc
frank mpbc over 6 years ago
Could someone recommend a 0201 footprint that is well proven for good from personal experience for reflow assembly?
Frank
  • CadAce2K
    CadAce2K over 6 years ago in reply to frank mpbc +1
    community.cadence.com/.../7242.COMc0603x33n.zip \ Try these. We commonly use differing footprints for devices. This includes caps, resistors and inductors (all 0201 INCH size).
  • frank mpbc
    frank mpbc over 6 years ago in reply to CadAce2K
    I downloaded this morning from Ultralibrarian for Vishay CRCW020110K0FKED. It looks real different from the Vishay recommended pads.
    UL:
    Vishay
    https://www.vishay.com/docs/20052/crcw0201e3.pdf
  • frank mpbc
    frank mpbc over 6 years ago in reply to frank mpbc
    The file from SnapEDA did not build properly. There is no copper.  It has only .psm for the padstack, no .pad
  • CadAce2K
    Yep. Looks like this was created under 16.3 and it doesn't pop up the padstack editor correctly. I've messed with it a bit, and still can't get the script to run. Good thing there's so many other options.
  • CadAce2K
    You can also download Library Expert Pro from PCBLibraries (free) and learn it to create most anything. My co-worker also uses the Cadence-centric Orcad Library Builder (haven't tried it).
  • frank mpbc
    Don't worry about the SnapEDA symbol. If you have a personal symbol that went many times through fab process, you could upload one .dra from your personal library. The mentor site has lots of justification on the choices they made.
