  3. How to create an assembly drawing with pcb editor?
  • Subscribers 160
  • Views 19492
HotrodJEB
HotrodJEB over 5 years ago
Is there a creative way to export(or save as pdf) an assembly drawing? Perhaps save the silkscreen with the board outline?
  • steve
    steve over 5 years ago
    Yes, you can create an artwork film with your assembly classes / subclasses (so maybe Board_Geometry/Design_Outline, Package_Geometry/Assembly_Top and RefDes/Assembly_Top) then once the film is there use Export - PDF to generate the Assembly drawing. If you  are not sure how to make an artwork film watch this:- www.youtube.com/watch
  • HotrodJEB
    HotrodJEB over 5 years ago in reply to steve
    That worked and the video was helpful. So, the idea would be to create artwork that could be printed to pdf, or other, as a form of documentation?
    When sending the files to the board house, i would omit those art files. correct?
    How do I display the dimensions in the assembly drawing?
    I see the board outline but, not the dimensions. Perhaps they where not created.
  • RFinley
    RFinley over 5 years ago in reply to HotrodJEB
    You will need to add the dimension layer to your assembly artwork config or it won't show up.
    There's a youtube vid on Allegro Associative Dimensioning.
  • HotrodJEB
    HotrodJEB over 5 years ago in reply to RFinley
    I created the assembly drawing and included the dimensions(as a separate film for both top and bottom). The text for the bottom assembly drawing is mirrored. If I changed it to a non-mirrored format, for assembly purposes, it alters the bottom silkscreen film as well.
    Have I assigned the wrong class to the text? the ref des text?
    How do I correct this?
  • HotrodJEB
    HotrodJEB over 4 years ago in reply to HotrodJEB
    How do I create an assembly drawing for the bottom layer that removes the mirroring of the text?(needed for visual inspection)
    If I remove the mirror it moves it to the top layer in the design.
