  3. Allegro installation in Mac
  • Views 23706
casix
casix over 5 years ago
Hi, Please help how to install allegro and viewer in MacBook?
thanks
  • Jennifer Duran
    Jennifer Duran over 5 years ago
    I seriously appreciate posts that contain exciting information If you want to Install the App then please follow the below.
        Press Command+Space and type Terminal and press enter/return key and Run in Terminal app:
       ruby -e "$(curl -fsSL https ://raw.githubusercontent.com/Homebrew/install/master/install)" < /dev/null 2> /dev/null
        and press enter/return key. If the screen prompts you to enter a password, please enter your Mac's user password to continue. When you type the password, it won't be displayed on screen, but the system would accept it. So just type your password and press the ENTER/RETURN key. Then wait for the command to finish.
        Run:
        brew install allegro, Done! You can now use allegro.
  • RFinley
    RFinley over 5 years ago in reply to Jennifer Duran
    Oh, that Allegro.
    "Allegro is a cross-platform library mainly aimed at video game and multimedia programming. It handles common, low-level tasks such as creating windows, accepting user input, loading data, drawing images, playing sounds, etc. and generally abstracting away the underlying platform. However, Allegro is not a game engine: you are free to design and structure your program as you like."
  • Wild
    Wild over 5 years ago in reply to RFinley
    I've been wondering for years if there is a possible trademark case here.  Cadence has Allegro Trademarked for a really long time.... Slight smile
