  3. PCB editor interface not scaled on high resolution disp...
  • State Verified Answer
  • Subscribers 166
  • Views 24287
PCB editor interface not scaled on high resolution displays
eddoh
eddoh over 5 years ago
I am working on a 3840x2160 display on Win 10 64 and - while I have no specific issues with Orcad Capture, things get really messy using PCB Design.
I have managed to increase the size of text, which is bringing some weird interface, as the font scales but not the interface - so text lines are clipped (see below) but I can manage.
I'm aware I could increase the size of icons, but at the moment they look just fine.
I know I could change the system Display resolution but doing that everytime I need to swap from PCD designer to another app is a real pain. (As global scaling in making the Windows Taskabar bulge and so on)
What is really a showstopper is the fact that checkboxes do not resize, they stay about 1mm wide and the checkmark is really barely visible - see below
Is there some setting somewhere which can improve the situation?
I'm sure there are quite some users with High res displays nowadays
Thanks!
  • mcatramb91
    mcatramb91 over 5 years ago +2 verified
    Hello, I have seen this happen on multiple display configurations with different resolutions and font scaling. Starting the Layout Editor on a display at different resolution and font scaling than moving…
  • JuanCR
    JuanCR over 4 years ago in reply to soll +2
    Actually, ALLEGRO_HIGH_DPI_ENABLED is not a User Preference setting. It is a OS level variable. You have to go to your Env. variables of your system and set it up there. Follow this image:
  • JuanCR
    0 JuanCR over 4 years ago in reply to soll
    • Vote Up +2 Vote Down
