  3. PCB Editor: how show component properties on PCB
  • Views 22132
eddoh
eddoh over 5 years ago
Hi there.
What is the working way to show the component Value on a PCB board ?
Tried adding in the Symbol drawing definition (dra) of the symbols a Label using the Layout>Display>Label>Value menu. Placed the placeholder, say , on Component_Value>Silkscreen_top
When I process the board, the values are properly transferred, as I can see routing the board.
Next I edit the text to match a size, whose Photo Witdth is not 0. Do the same for a text of say, the package_geometry class to test.
The Component_value class does not show up on the 3D view of the PCB, the PackageGeometry does.
So this looks like a dead end.
What am I doing wrong here?
  • steve
    steve over 5 years ago in reply to eddoh +1
    OK...... Make sure you are in General Edit Mode (Setup - Application Modes - General Edit). In the Find pane turn off all objects except text. Hover over the Value text and right click - Change Class/subclass…
  • eddoh
    eddoh over 5 years ago in reply to steve
    Thanks! That was the right way -it works Slight smile
