  3. How can I assign ground shape 20 mil away from the outline...
  • Replies 9
  • Subscribers 167
  • Views 20210
How can I assign ground shape 20 mil away from the outline using PCB editor 17.4?
frank673
frank673 over 5 years ago
Following is the outline I have created using imported DXF.
My intention is to create a shape in layer - 02, 20 mils away from the outline. How can I do that?
( I tried the z-copy method and it failed with the following error message: " Not a closed polygon or CLine, element ignored". Also, I could not find the option Shape -> Compose Shape in PCB editor 17.4)
  • excellon1
    excellon1 over 5 years ago in reply to frank673 +2
    Frank in the PCB Editor go to Setup>User Preferences on the tool bar. In the dialog box search for legacy. You should see something like orcad_use_legacy_menu. Checking this box and doing a restart of…
  • redwire
    redwire over 5 years ago in reply to frank673 +1
    Great, glad that worked but did you try the "modern" menu command "Shape->Create from lines"? It should work the same way. I have too many years under the old menu to go to the modern menu but I would…
  • frank673
    frank673 over 5 years ago in reply to redwire
    This was really helpful. Fixed the issue. I am curious to know how to go back to the menu structure of 17.4 as well.
  • excellon1
    Frank in the PCB Editor go to Setup>User Preferences on the tool bar. In the dialog box search for legacy. You should see something like orcad_use_legacy_menu. Checking this box and doing a restart of the PCB editor makes the menu system the Allegro Default. I think most on here are using that.
    My preference is to use the Allegro menu structure, hence I have that Legacy Menu checked by default. As red pointed out you will see more options pop up when you click on "Shape" on the tool bar.
    You can switch back anytime to the Orcad menu structure by un-checking the box and restarting the PCB Editor.
    All the best.
    • Vote Up +2 Vote Down
  • redwire
    Great, glad that worked but did you try the "modern" menu command "Shape->Create from lines"?  It should work the same way.  I have too many years under the old menu to go to the modern menu but I would suggest staying modern as that is the way the tool is going.
  • frank673
    Just tried and it worked. Yes, the plan is to stick to the new menu. Thank you.
