  3. Set a Fixed Grid Column Width
  • Subscribers 159
  • Views 13427
leto
leto over 4 years ago
Hello All,
I'm creating a Grid with many columns. The grid has a fixed width that is set in the .form  file
I've also set the individual column width with the    "colWidth"   attribute.
However when the grid is created the column width is auto reduced to fit the Grid width and does not follow my  "colWidth" settings.
How do I set in the SKILL code to fix the column width.
Thanks All
  • leto
    Hi All,
    Is there a SKILL command that I can use to change the column width in a grid during runtime?
    Thanks All
