  3. Cannot load symbol
  • Replies 9
  • Subscribers 166
  • Views 21870
Cannot load symbol
JoNie
JoNie over 5 years ago
i completed a schematic design in OrCad Capture and i wanted to create a new layout of the circuit at pcb editor. My circuit consists of some capacitors,resistors,inductors and the IRF150 transistor.The problem is that all components can be placed at the design in pcb editor except for the IRF150 and when i try to place it command window gives the message : " Cannot load symbol '806' ". Could anyone help on this?
Thank you.
  • JoNie
    JoNie over 5 years ago in reply to steve
    Indeed the schematic symbol has 3 pins. Before i go on i want to mention that using the IRF150 with the PCB footprint name TO204AE and simulating the circuit i dont get the response that i get using the IRF150 with the 860 PCB footprint name . Is there a problem or it will be ok even if i use TO204AE footprint?
  • steve
    steve over 5 years ago in reply to JoNie
    The PCB Footprint property has nothing to do with the simulation. You may need to explain what you mean by I don't get the response?
  • JoNie
    While designing  the schematic of my circuit (before PCB design) PSpice has multiple choices for the transistor IRF150 that i want to place . One  of them has PCB footprint name 860 (and when i simulate my circuit i take the desired response,that is the voltage i want at the output) and another choice has PCB footprint name ,as you told me , TO204AE (but the simulation results at time domain arent the desired). I asked if there is a problem if i use the TO204AE for the PCB design even thogh the simulations of PSpice are not the desired
  • AvengerThanos
    AvengerThanos over 5 years ago in reply to JoNie
    Check whether you have provided the padpath and psmpath (path where the PCB footprints are located) in user preferences of PCB editor
